rs 232 adaptor
  • murdock
    • Oct 2007
    • 2346
    rs 232 adaptor
    i need some help...i purchased an adptor to connect a logger to my laptop...when i connect the instrument to the 232 port on my office pc it downloads all the data and communicates with the logger...problem now is i need to annalyse on site so i went and purchased a meccer adptor so it connects to a usb port but it keeps indicating error messages all the time and baud rate incorrect...but when i connect to the 232 port without the adptor on my office pc no errors...help needed.
  • duncan drennan
    • Jun 2006
    • 2642
    XP or Vista? Does the USB to serial adapter register as a Prolific device?
    Check by going to Control Panle -> System -> Device Manager, then find the ports and see what devices are registered.
    I had a problem with a USB to serial device under Vista and had to download an updated driver.
    • murdock
      • Oct 2007
      • 2346
      xp and yes it does.
      • duncan drennan
        • Jun 2006
        • 2642
        How do you set the baud rate settings in the PC software for the meter?
        If you know what the settings are you can try to set them directly on the USB adapter by going into the device properties (double click in the device manager), and then under Port Settings try to set the defaults to the correct values.
        • RKS Computer Solutions
          • Apr 2007
          • 626
          Murdock, has the issue been solved? If you contact me I can put you in contact with the right people in order to get it sorted for you
