Relational Database Design
  • ultramel123
    • Feb 2013
    • 29
    Good Morning
    I am putting together a plan for a database which can be used to keep track of our client's rates, supplier cost and profit. I am however struggling with which tables would be best suited ?
    So far I have the following which does not seem to be correct - and I cannot get my head around a better solution:
    tblClients - would contain basic client information
    tblInventory - would be the various services we offer
    tblPriceList - (lookup inventory code from "tblInventory" ) and also contain the customer's rate.
    tblSuppliers - basic supplier information
    tblSupplierRates - (lookup inventory code from "tblInventory") and also contain the supplier's rate for that particular service
    Reports:
    Profit Report - reflects the list of clients - along with the client rate from tblPriceList - and compares it with the supplier rate from tblSupplierRates
    - the problem is that more than 1 supplier can have a rate for each different inventory item
    Any advice or guidance will be appreciated
    Thank you
    • 22820
    Originally posted by ultramel123
    Reports:
    And rates can vary not just against suppliers, but also over time. I suggest introduce a date field for each of those rates.
    Are you using this for estimating purposes or for tracking actual costs against actual projects?
    • ultramel123
      • Feb 2013
      • 29
      Thank you. I will use a date for the rates to be valid from - and until ( for example 1 year and then they can be reviewed)
      it is to be used for tracking actual costs against actual projects ...
