Convert Word to Pdf
  • Faan
    • Jan 2007
    • 123
    Convert Word to Pdf
    How do I go about converting a word document to a Pdf file with the option of a password facility.
    Faan Kruger
    +27 82 853 7879
    krugerfaan@gmail.com
  • Chatmaster
    • Aug 2006
    • 1065
    You can use a program PDF Creator.
    • Faan
      • Jan 2007
      • 123
      Thanks Roelof. We have just had our one hour of no power.
      Faan Kruger
      +27 82 853 7879
      • Moneymaker
        • Mar 2008
        • 43
        Does it have a password facility.....?
        • Chatmaster
          • Aug 2006
          • 1065
          As far as I know it does. I used the older version before and it had a password facility.
            Try Primo as well http://www.primopdf.com/ I use it on PCs where we don't have genuine acrobat.
            • duncan drennan
              • Jun 2006
              • 2642
              pdftk can do it all, but is only for command line use. PDF555 has a fancy GUI, and can also do it all.
              • duncan drennan
                • Jun 2006
                • 2642
                I didn't realise that PDFCreator could apply passwords to docs, so I had a closer look....
                When you print, the dialogue for naming the file comes up. Click on options. There is a menu in the bottom left, click on PDF. On the right there are tabs, click on the security tab. Then click the "USe Security" check box. Figure out what options you need, and then save. When you save the file it will ask you for a password.
                This is a nice way of generating SARS compliant electronic VAT invoices. You would need to select the following options,
                1) Encryption level = High (128 bit)
                2) Password required to change permissions and passwords
                3) Disallow user to "Modify document" and "Modify comments"
                Visual instructions....
                [ATTACH]292[/ATTACH][ATTACH]293[/ATTACH][ATTACH]295[/ATTACH][ATTACH]294[/ATTACH]
                • Faan
                  • Jan 2007
                  • 123
                  Thanks Duncan
                  Faan Kruger
                  +27 82 853 7879
                  • Moneymaker
                    • Mar 2008
                    • 43
                    Great....
                    I'd been using it for ages and had no idea it could do this....and a package that's free too!
                      Given that I've been getting a steady drip in my inbox about a PDF converter that "only" costs 79 Euros, this thread is manna from heaven.
                      Thanks everyone.
                      • Faan
                        • Jan 2007
                        • 123
                        Dave,
                        It looks as if I should have asked this question a long time ago! You may pass half of the 79 Euros on to me and it will still be a bargain!
                        Faan Kruger
                        +27 82 853 7879
                          Nice try, Faan.
                          • Neoplan
                            • Dec 2008
                            • 3
                            Try Altsoft Xml2PDF (http://alt-soft.com), as far as i khow it has the function of setting the password to output pdf document
