my computer has become increasingly slow over the last month or so, and my hard drive has been making strange sounds lately. just want to know if my hard drive is breaking or if there could be something else wrong?
strange hard drive noises
Definitely what Dave said! It can take months or it can take minutes but, one day, you will wake up and all your data will be gone.
Make the backup and replace your hard drive asap.Norio De Sousa - Just1.co.za (Cheap web hosting & website builder)
Maxiware CC Reg no. 2000/048244/23 (Maxiware CC)Comment
BOVER Technologies - computer sales and TeamViewer support
Elmine Botha Freelance Photographer - Photographer/ VideographerComment
Maybe gecko's hard drive died and that's why he's not back.
(Or she I guess - you never know nowadays)
hey im back!
thanks for the help your asap's really did help. my hard drive crashed last week and i had to get it replaced, copied everything and now i still have all my valuables that were on there, phew thank goodness.
why did it crash though, did i over use it?
the guy that fixed it said i had dropped it, but unless it myseteriously fell when i was not around, it couldnt have been that.Comment
Something as simple as the failure of a capacitor on the power supply could also stop a hard drive from working, but that wouldn't have warning noises. The chances of the electronics breaking (under normal conditions) are lower than the chances of the mechanical bits failing.
|Comment
Also a big case with fans in front and back will also help air circulation and will affect the temperature in the case.
I would like to hear your opinions on the hard drive cooler.
Thanks.
At least hard drives a lot more durable nowadays. Back in the early days of PCs you could only expect about 18 months life out of them - something about a controller that had a nack for getting tired really quickly.Participation is voluntary.
Ok Duncan - if you use a big case and 120 mm fans it helps a bit for the noise - it spins slower and move a lot more air than the 80 mm fan and is not as loud and have a different frequency - not so irritating.
For the hard drive cooler - it is very quiet - I don't hear them at all - but I must admit that I am hard of hearing!
i didnt even see it coming...only now that the hard drive is out the box can i hear the "strange noise" my drive with all my backups crashed on sunday morning i lost everything all my reports...pictures...my entire bussiness records the whole lot.
i have since decided to invest in an external 500gig hard for backups and a 8 gig flash drive another 500 gig drive and keep both as backups so if one goes down the other will have the info saved...i just need to find someone to set the pc up now that if automatically backs up all the data so that i dont have
one of the major causes of hard rive failure is an erratic power supply...i decided to connect my logger to the power in my office and i can see why my hard drive packed up...i had disconnected my UPS for maintenace reasons so it has been off for a couple of weeks...i just never got around to servicing it.
word of advice if you have pc make sure you have a UPS connected...the online units are more expensive but will save your components in your pc.
something else i have learnt about cooling and air circulation it works a lot better if you blow into a chamber fill it with air then exhaust it...rather than sucking air out of a chamber...just some usless information.Comment
Have you at least got reliable data on your debtors ledger? (Losing that would be my number 1 nightmare).Participation is voluntary.
