I take it that your system is network based. Remote Administrator is a capability of Windows XP pro and only the more Powerful Vista OS like Ultimate. With this tool you can log into the other computers and send the information to you by taking control of the system. It is easy to set-up and runs OK on a network.
Remote Administrator can work here, all you do is you share a temporary folder and log into the computers and start the copy process on the network. After you are done you just log out of the computer and log into the next. But there is a much easier way to this.
Here is a brainwave you can try. Set up a folder for each user on your server. Map the folder to their desktop and let them work from it. Give them an ID code along with the file name.
Example: file name 01 (Identify the user with the 01) and if someone edit the document let them put their number in place of the 01. So user one is 01 user two is 02. Thus the document will be saved as document01.doc by user 1 and document02.doc for user two thus you don’t get everyone working on the same document all the time! Only if they need to they can correspond with the file in question.
Now everything will be opened and saved onto the server ALL THE TIME thus you only need to back up the drive with the folders on them. “this is really primitive but it works” I know of two small companies that work this way “they don’t want to spend the money for a proper server system” It works okay but take care this can become tricky! Trust me it can become a nightmare if you lose sight of it!
