May Telkom burn!
    Originally posted by SoftDux
    And, I now pay R290 for 10GB bandwidth.
    That would be shaped bandwidth
    Well, my Neotel solution went out the window. My location doesn't have coverage. 150 metres away but at my spot
    Close, but no cigar.
    So it looks like I'll have to go with Telkom unshaped after all
    • SilverNodashi
      • May 2007
      • 1197
      #32
      Does the unshaped bandwidth really make such a big difference to you?
        Shaped connection - IMAP doesn't work.
        Unshaped connection - IMAP does work.
        • SilverNodashi
          • May 2007
          • 1197
          #34
          I use Africhost + IMAP, and I recently deleted about 20GB worth of old email (backups was taking too long). so it works fine for me
            Would that be to a local or overseas server, SoftDux?
            When I checked with their technical department, AfriHost was clearly expecting a problem making an IMAP connection to an overseas server.
            Anyway - got the unshaped service going today and the IMAP connection works perfectly.
            And emails download much faster...
            • SilverNodashi
              • May 2007
              • 1197
              #36
              This is on gmail.com which is in the USA. I'm going to setup a local IMAP server soon and transfer all of this to the local server, purely cause I need more control & functionality.
                Yeah, I tested gmail and it worked for some reason, possibly because the gmail IMAP connection isn't "typical". I wasn't happy using gmail to distribute the kind of corporate communications I've got in mind for this system, though.
                And from the bit of testing I've done already, it's clear that unshaped is a whole lot faster for a whole range of protocols. It's internet the way it's supposed to be.
                Funny, you never know what you're missing until you try it.
                • jinxster
                  • 36
                  #38
                  Hi Dave,
                  Ok I am a new member here.
                  I have (sell):
                  Semi shaped service - R40 per gb
                  Prepaid service - R75
                  626 unshaped service - R50
                  Shaped Service - R110 per gb
                  Local - R10 per gb
                  In answer to SoftDux, you cannot really compare a diginet line to a DSL line by means of the number in front. A 64kb diginet line is quoted on kilobytes and the 4mb is quoted on megabits. But I agree, DSL gives more for your money.
                  On a 64kb diginet you should be downloading at a speed of 64kb/s. So a 64mb file should take you 1024 seconds about 17minutes to download.
                  On 4mb DSL line, you should be able to get 4096 / 10 (start and stop bit included) 410kb/s which is higher. However your throttled on the upload and like Dave says shaped services generally start putting you to the back of the queue for "non mainline home use" contention services and hence you may just find that if Dave lowers his speed he may actually see his IMAP working.
                  Some advice outside of changing your connection is to use a VPN... our service includes a vLock and vDNS (like Axxess since I resell their services) which can assist you in your IP changing and VPN needs.
                  In reality 410kb/s on a 4mb line doesn't exist. It is a "burstable" service. So at max speed that is what you would get. The average DSL line is shared with 3 other subscribers so if they sleeping you could get your 410kb/s. However you dont get that anyway becuase things are happening at an un synched speed, like the government queue issue issue, you downloading your file you get packets that must wait in line, then they get lost and then tcp/ip fixes the problem by saying... send packet xyz again pease.
                  This means if you downloaded the same 64MB file on the 4mb DSL line, you may be able to get (best case scenario) the file in 160 seconds. But in reality you end up waiting in queues and lost packets occur and hence you actually need to download 128mb to get your 64mb file.
                  You must understand the DSL is still a shared service and T lines and diginet lines are still where guarentees come in. The downside for T / diginet lines is the internet mesh is so well connected the users dont see problems much anymore. But I still havent seen such great speeds as the speed of the lines go up which means that Telkom are still sharing us and as people get more, we actually are competeing our own service down.
                  If I were to sell at R29 a gig i would actually lose out on the debit orders since the cost of the debit order pushes my cost over the R29. However what I think afrihost may be doing is (dont quote me on this maybe one of their customers can help me out), they run 2 companies, claim the VAT back on the purchase of the service and then dont give out VAT invoices from another company and so, they make the 14% profit (which is actually about 9% if you take into account the banking charge and so on. Does anyone get an invoice from afrihost? and do they send to all customers? I hear some customers complain they cannot get a VAT invoice then when it mysteriously appears the name of the company changes....
                  So if that is true, then SARS may go knocking on their door one day... but Afrihost may magically fix that too before SARS get to the actual audit.
                  Many thanks
                  Andrew
                  • SilverNodashi
                    • May 2007
                    • 1197
                    #39
                    Originally posted by jinxster
                    Hi Dave,
                    I have (sell):
                    Local - R10 per gb
                    Many thanks
                    Andrew
                    Wow Andrew, careful with the advertising spam. P.S. Afrihost & Axxess can offer those prices since they "write off" the extra fees on advertising, marketing, etc. They take about R10/GB off of what IS charges them, but they gain those clients back much quicker than you do And they're not skimming on their VAT so be careful of such an accusation.
                    P.S. I been in the industry much longer than you think and know very well how DSL & diginet works. My comparison was a bit different and still stands.
                      Hi Andrew
                      I get a valid tax invoice from Afrihost, maybe they just get better rates than you.
                        Interesting. However you cannot ignore the fact that we have only one service provider “Telkom”
                        and everyone else is just dealing trough Telkom. Fact is Telkom is cost effective but you would be surprised that TELKOM still doesn’t offer DSL in my aria. We are still stuck with 56k dial up and downloading your mail from that will up your stress and end up killing you...
                        If you want to send your family a Video clip or even use Skype on 56k I am sorry but you are dead in the water. Vodacom works OK most of the time but even with a tower being so close I can read the no-entry signs on it; it doesn’t help with my speed.... “Rather doesn’t help with my speed anymore” it use to be good.
                        In all honesty it is still cheaper to have DHL deliver a HDD then sending info via the net. In short you don’t get your money’s worth.
                        case and point with TELKOM: http://www.telkom.co.za/products_ser..._dsl_cost.html
                        • jinxster
                          • 36
                          #42
                          Hey im not here to fight, I didnt mean you were wrong SoftDux, I actually agreed with you on speed issues just added something for other people.
                          With regard to your advertising spam, you guys brought up Afrihost @ R29 first.
                          Then I hear your comments about advertising markets and budgets, but er...
                          Have you ever thought to yourself... sometimes it is too good to be true... what is the scam.. is there a scam.
                          I am in no way insinuating a scam. However, when it comes to a company t/a another company name.........
                          Most large tenders automatically disqualify you. Let me try and explain without making anyone mad or being sued...
                          Lets call it.. mytaxname t/a myadvertisedcompany
                          mytaxname is what all my tax submissions get sent on... when I sell something I tell my customers myadvertisedname. This is perfectly fine however the trading part is the part that collects the VAT, so your VAT registration must have that name registered somewhere in it... go check out afrihost (wont mention their other company name) and it seems like there are 2 VAT numbers for the first bit and 0 for the second... hmmm so which is it...
                          The art of creating confusion to delay time...
                          Second... how long has this advertising budget been in play? it clearly states.. a limited number... seems like a very large limited number to me hey.. wonder how much money they got available in advertsing alone....
                          Now I am not saying Afrihost is scamming in any way. Im just going to tell you how you get some capital.
                          Basically... there is a ficticious number in companies called... Goodwill.
                          It is an asset, just like having a car / building / equipment / etc. However it is an intangible asset that cottons on to the market edge the company name has. (whats in a name). If you have a good name you can say.. i have an intangible asset of R1m... R2m, R200m. It happens. However if the company closed it doors and never traded again it would be sold @ R0. So, why make this asset, accounting people will tell you.. when you sell he company... great thats cool, why would you have one in your balance sheet when the company isnt being valued? Well, it beefs up your surety power at the bank and hence you get nice beeeeeg loan. R200m Goodwill = R150m overdraft facility for most banks, its an overdraft, not a long term loan. Overdraft for advertising... sorry that slipped out
                          The major price decreases started end of Dec 2009 mostly.. why was Afrihost sooo much cheaper sooo much earlier and they never tendered for any government contracts? Co incidence? When did the SEACOM cable get finished?
                          They get better rates... maybe... maybe not.. just saying its easy to make liquidity if you make intangible assets....
                          Technically if Afrihost have their real trading name on the invoice, you got yourself a valid VAT invoice. I havent seen any invoice from Afrihost ever, so I have no comment on if they are true or not just pointing out minor details that create millions.
                          Check SARS VAT vendor search, I dont find Afrihost or Afrihost Internet Services. Maybe I spelt it wrong...
                            I see a snag. As far as I know, you can't add goodwill to a balance sheet without a sale
                            • jinxster
                              • 36
                              #44
                              Hence you make more and more sales by selling at half price....
                                Jinxster
                                I checked the Afrihost invoice and their VAT number is registered.
                                So I am happy that I have a valid Tax invoice.
                                One thing they have to guard against is jumping to the wrong conclusions without all the facts. Afrihost have said they get their Internet from IS so they must get a better deal than you hence can sell it cheaper. Anyway they seem quite open and are quite active on MY Broadband, If you search there you will get a lot more info.
