Apache warns Web server admins of DoS attack tool
  • SilverNodashi
    • May 2007
    • 1197
    Anyone who runs an Apache webserver should urgently look into securing their server(s) ASAP to avoid any DDOS attacks, as per this email from Apache:
    > Subject: Advisory: Range header DoS vulnerability Apache HTTPD 1.3/2.x \(CVE-2011-3192\)
    > Date: August 24, 2011 9:16:39 AM PDT
    > To: announce@httpd.apache.org
    > -----BEGIN PGP SIGNED MESSAGE-----
    > Hash: SHA1
    > Apache HTTPD Security ADVISORY
    > Title: Range header DoS vulnerability Apache HTTPD 1.3/2.x
    > CVE: CVE-2011-3192:
    > Date: 20110824 1600Z
    > Product: Apache HTTPD Web Server
    > Versions: Apache 1.3 all versions, Apache 2 all versions
    > Description:
    > A denial of service vulnerability has been found in the way the multiple
    > overlapping ranges are handled by the Apache HTTPD server:
    > Full Disclosure: Apache Killer
    > An attack tool is circulating in the wild. Active use of this tools has
    > been observed.
    > The attack can be done remotely and with a modest number of requests can
    > cause very significant memory and CPU usage on the server.
    > The default Apache HTTPD installation is vulnerable.
    > There is currently no patch/new version of Apache HTTPD which fixes this
    > vulnerability. This advisory will be updated when a long term fix
    > is available.
    > A full fix is expected in the next 48 hours.
    > Mitigation:
    > However there are several immediate options to mitigate this issue until
    > a full fix is available:
    > 1) Use SetEnvIf or mod_rewrite to detect a large number of ranges and then
    > either ignore the Range: header or reject the request.
    > Option 1: (Apache 2.0 and 2.2)
    > # Drop the Range header when more than 5 ranges.
    > # CVE-2011-3192
    > SetEnvIf Range (,.*?){5,} bad-range=1
    > RequestHeader unset Range env=bad-range
    > # optional logging.
    > CustomLog logs/range-CVE-2011-3192.log common env=bad-range
    > Option 2: (Also for Apache 1.3)
    > # Reject request when more than 5 ranges in the Range: header.
    > # CVE-2011-3192
    > RewriteEngine on
    > RewriteCond %{HTTP:range} !(^bytes=[^,]+(,[^,]+){0,4}$|^$)
    > RewriteRule .* - [F]
    > The number 5 is arbitrary. Several 10's should not be an issue and may be
    > required for sites which for example serve PDFs to very high end eReaders
    > or use things such complex http based video streaming.
    > 2) Limit the size of the request field to a few hundred bytes. Note that while
    > this keeps the offending Range header short - it may break other headers;
    > such as sizeable cookies or security fields.
    > LimitRequestFieldSize 200
    > Note that as the attack evolves in the field you are likely to have
    > to further limit this and/or impose other LimitRequestFields limits.
    > See: http://httpd.apache.org/docs/2.2/mod...questfieldsize
    > 3) Use mod_headers to completely dis-allow the use of Range headers:
    > Note that this may break certain clients - such as those used for
    > e-Readers and progressive/http-streaming video.
    > 4) Deploy a Range header count module as a temporary stopgap measure:
    > http://people.apache.org/~dirkx/mod_rangecnt.c
    > Precompiled binaries for some platforms are available at:
    > http://people.apache.org/~dirkx/BINARIES.txt
    > 5) Apply any of the current patches under discussion - such as:
    > http://mail-archives.apache.org/mod_...l.gmail.com%3e
    > Actions:
    > Apache HTTPD users who are concerned about a DoS attack against their server
    > should consider implementing any of the above mitigations immediately.
    > When using a third party attack tool to verify vulnerability - know that most
    > of the versions in the wild currently check for the presence of mod_deflate;
    > and will (mis)report that your server is not vulnerable if this module is not
    > present. This vulnerability is not dependent on presence or absence of
    > that module.
    > Planning:
    > This advisory will be updated when new information, a patch or a new release
    > is available. A patch or new apache release for Apache 2.0 and 2.2 is expected
    > in the next 48 hours. Note that, while popular, Apache 1.3 is deprecated.
  • SilverNodashi
    • May 2007
    • 1197
    If you're using CentOS / Red Hat and probably any other Red Hat derivative like Fedora Core or Scientific Linux then you can apply the following fix:
    create a file in /etc/httpd/conf.d/ like for example "/etc/httpd/conf.d/CVE-2011-3192.conf" and add the following to the file:
    Code:
             # CVE-2011-3192
             # optional logging.
    I'm not sure if this structure will work on Debian / Ubuntu / OpenSuse / etc systems, but on Red Hat type Linux systems Apache will read any file in the /etc/httpd/conf.d/ folder with a .conf extension.
    • Perform Computers
      • Feb 2011
      • 323
      Friends don't let friends use RedHat.
      • SilverNodashi
        • May 2007
        • 1197
        How hard did your hosting company laugh when you told them that??
        • Perform Computers
          • Feb 2011
          • 323
          Pointless wasting energy trying to convince them to use FreeBSD.
