static or dynamic ip address
  • murdock
    • Oct 2007
    • 2346
    been doing some research....so i can complete my cctv installation and be able to view my cameras from anywhere on the net.
    i want to be able to connect to my office which will be linked to the dvr...i am not sure if i should connect a 3/4 G modem or use the telkom router.
    i want to be able to receive sms or an email if the alarm is activated....then view the cameras from my netbook which has a 3 G card in it...i do realise that the 3 g route would be more expensive.
    some recommendations are that i use a router to avoid virus and other complications and that i should use a dynamic ip address?
    what are your thoughts.
    I always set up static ipaddresses for all pc's and servers on my routers. I have a very particular addressing scheme which just makes life easier as the network evolves. I also prefer it that way for managing security, permissions, exceptions etc.
    • twinscythe12332
      • Jan 2007
      • 769
      I'm not so sure on the smsing, but for viewing you should probably go static since you will need to allow traffic through your router. It becomes a bit more difficult when the IP of the machine you're trying to reach keeps changing. The benefit of a router is normally the firewall that comes with it. All the machines coming out of your network look like they're coming from one IP.
      • Quini
        • 6
        You can connect an SMS unit to the alarm system, Thisis al determined by a IO board output on the alarm system... Basicly what happens is the same as the out put that goes to the siren, the sms unit will recieve a signal and then send the sms to a programed number.
        Then as far as remote viewing goes, My recomendation is that you incorporate a uncapped ADSL line at the office (on DVR side) and there should be no issue connecting from a 3G unit connected to your notebook... In some instances we used to supply sustems that alow you to view via your sellphone
