What is the fastest web server?
  • twinscythe12332
    • Jan 2007
    • 769
    As usual, I'm skeptical on any benchmarks. But this doesn't look too bad. It may not cover everything that gets done on a web server, but it's something to look at (also, bar charts!)
    • 22820
    Originally posted by twinscythe12332
    It may not cover everything that gets done on a web server...
    Something of an understatement
    There's also the "done with out-the-box settings" issue which I suggest might also be skewing results some.
    • twinscythe12332
      • Jan 2007
      • 769
      At least it should be uniform =P
        • 22820
        I'm fairly confident MS pays far more attention to default settings than the community projects do...
        ...and MS doesn't have to deal with the inherent problems of obtaining consensus out of a committee of unpaid, maniacal volunteers either.
        • irneb
          • Apr 2007
          • 625
          Well if you read their own comment about why they still use Apache: The difference is actually so infinitesimal as to be more than likely swamped by normal latency times. Thus you'd probably not even notice the difference between the fastest & slowest servers in those tested. And thus (for them at least) the overruling factor is: "Which server gives us the features we need?"
          • kailashseo368
            • Feb 2013
            • 16
            Apache server
            • markspend01
              • Jun 2013
              • 5
              Hey Guys well i think that the Apache server is the most efficient.It is free so it is regularly being customized to best fit the credentials for the best possible web server.Thanks!!
              S-Type Load Cells
              • polpak
                • Jun 2013
                • 33
                Any differences observed between Apache server for Linux/Unix or for MS-Windows ?
                  • 22820
                  IIS is the Microsoft server product tested and came out the clear winner.
                  (Hence the controversy, as it were).
