The thing with induced or capacitively coupled voltages is that they can be deceptive. Depending on the input resistance of your test meter you'll get different voltage readings. The whack you get from it is more down to the energy it can deliver, as previously stated this is more about the Amps or Joules.
If you can see the voltage on your tester then at least you can get a handle on what is causing the fault. What 2 points did you get your 6VAC measurement between? I would first try to narrow it down to which circuit is causing the reading, isolate all circuits at the DB, check that the 6 Volt reading has gone then reset each circuit one by one to establish which is the guilty one.
