Load shedding
http://www.smashwords.com/books/view/332256Comment
I received 3 dead printers this morning already, not a surprise, I have noticed over the years that when the power goes off I often get some surge damaged machines in the workshop. Power supplies and main boards are expensive, from these 3 machines only one might be economically repaired. I know it’s probably the power failure, or more accurately its return because I know all 3 of the machines did not switch on today- after yesterday.
Can one prove it’s caused by mesko? (eskom).Is there any recourse available for uninsured clients or insurance companies?It is not the strongest of the species that survive, nor the most intelligent, but the one most responsive to change. – Charles DarwinComment
I'm sorry no, I don't think so. I fear there's some fine-print in your elec connection contract which exemplifies Eskom from any damage cause by their supply inconsistencies.
For me, I've usually got my home PC's and most electronic equipment behind a protection device. But that's mostly because of lightning here - surges I'm not too sure if they dampen those. Although I've had several UPS's die on me due to Eskom's poor quality power, I see them as sacrificial - much cheaper to replace a UPS than a PC motherboard, CPU, etc.Gold is the money of kings; silver is the money of gentlemen; barter is the money of peasants; but debt is the money of slaves. - Norm Franz
Only if you had a recorder connected at the time. Many insurance companies will attempt to get out of a claim if there is no lightning protection, and will add a clause to your policy if you don't have lightning protection, which some insurance companies have realised that lightning protection is a hit and miss because it is not designed to protect against over voltage , it is designed to protect against lightning which generates thousands of volts.
There is a device which is designed for over voltages created by load shedding, cable theft etc. I have installed these devices years ago and still prove to be a worthy device saving thousands of rands.
The company now makes a single phase unit for domestic installations.Comments are based on opinion...not always facts....that's why people use an alias.Comment
That sux, but I guess if it’s in the contract you got no leg to stand on. I still think that there may be some way to overturn the contract though...potentaillyI'm sorry no, I don't think so. I fear there's some fine-print in your elec connection contract which exemplifies Eskom from any damage cause by their supply inconsistencies.
I always advice any client who has had one machine’s boards knocked out to get a surge protector or UPS. If it’s a fax the protector must include line protection. It’s cheaper to buy a new surge protector (or UPS) than replacing the machine in most cases. I must also add that a surge protector is by no means a 100% effective, I have seen surge protectors go with a machine and I have seen a surge protector untouched whilst the printer blows a component -rare. Usually, but not always, those branded as Lighting protectors are what gets people confused, which is not exactly the same as a surge protector. I might have this wrong but I believe a true surge protector does not allow over or under current, whereas a true and only lightning protector only covers over current and blows- high surge.It is not the strongest of the species that survive, nor the most intelligent, but the one most responsive to change. – Charles DarwinComment
