Positioning of Hotwater Cylinders in roofspace
  • ELECT 1
    • Dec 2013
    • 78
    I am posting this as i am now a bit sick and tired of plumbers installing their HWC's bang in the middle of the roof space where the electricians are supposed to crawl. It makes the access further into the roof difficult.
    Electricians now have to crawl over the cylinder, or underneath some pipes.
    I think the plumbers should have a rethink with this practice.
    I get the impression that they think the roof space is just for them.
    Some times the element part is in such a position that virtually no maintenance or even checking can be done with out busting your neck.
    Its just plain common sense i thinks.
    Now my rant is now over thankyou
    Even worse is when they replace the geyser, the element faces the small part of the roof space. You have to remove roof tiles to get it out. One of the reasons i no longer repair geysers
    • mikilianis
      • Dec 2008
      • 125
      Likewise,I stay away from H.W.C. I have had to replacing ceiling boards and corroded drip trays, not worth it, customers think you are incompetent, breaking the ceiling to get to the H.W.C.when the plumber always climbs into the ceiling to work on the H.W.C. replacing a valve etc.
        Ideally the cylinder should be placed close enough to the trap door to not restrict access and to allow work on the thermostat/element/pressure control/pressure relief/vacuum breakers etc. while standing on a ladder with only the top half of your torso through the trapdoor.
        But it seems it is a standing joke by plumbers that they do everything arse about face, even to mounting urinals so high that you have to pee upwards to get most of your stream inside.
        On the other hand most new installations are made before the ceilings are installed and sometimes the carpenter places the trapdoor somewhere else than the position that makes most sense.
          • 22820
          One of the contributing factors is the shallow pitch of roofs nowadays, methinks.
          • ELECT 1
            • Dec 2013
            • 78
            When God was dishing out brains , the Plumbers certainly werent first in the queue.
            Please this is a joke, please dont take me seriously.
            I think the plumbing compliance certificate should also mention that a HWC should be installed in such a position that it doesnt hinder other services from being done.
            • Leecatt
              • Jul 2008
              • 406
              tunny enough i did a geyser on saturday where, as you said, the electrics were up against the roof tiles. Getting to it was are major endeavour and i had to close the trap door to have somewhere put my feet.
