The Electrical Certificate of Compliance explained
This is a sticky topic.
  • Siya Saver
    • Sep 2015
    • 4
    #106
    Thank you for the information. It is well received and appreciated.
    • SeanM
      • Mar 2018
      • 120
      #107
      Good Morning all
      When issuing a COC when there is a sale of a property, who do you get to sign the receipt there of?
      The seller or the purchaser?
      Either the customer asks for the COC or the estate agent and then ask you to drop it off at the attorney's.
      • Leecatt
        • Jul 2008
        • 407
        #108
        I hand it over to the person paying the bill
        • Sparks
          • Dec 2009
          • 909
          #109
          I hand the COCs' to the Attorneys, unless requested otherwise. I do not bother letting them sign as the person signing accepts it as a correct and valid legal document, thereby diminishing my responsibillity for the contents. I take care to ensure that it is valid, comprehensive and correct.
          • SeanM
            • Mar 2018
            • 120
            #110
            Evening
            Thanks to all that have responded.
            • SeanM
              • Mar 2018
              • 120
              #111
              Evening
              I have been asked to do the electrical installations for shipping containers that are to be sold as offices, I have been asked to issue COC's for the containers, is this possible as the container will be sold and connected to power on site where ever this may be.
                • 1490
                #112
                HI
                All you can do is test and complete the COC for the address where the container is standing when you test.Make sure you stipulate which supply it comes from on the Erf - I would add a pic of the container standing in position to the coc
                As soon as they move the container it will no longer be valid as the address has changed.
                I assume the client wants a COC so that he is confident that the work has been carried out correctly
                Make sure your client understands that the coc will only be valid within there yard and that you are not expected as part of your costs to travel to the other side of the world to test
                • Sparks
                  • Dec 2009
                  • 909
                  #113
                  SeanM on completion of a new installation you must issue a COC.On page 1 of the COC you leave out the adress, the rest must all be completed. On page 2 you leave out the adress, the type of supply system and the characteristics of the supply. Under the installation description you select 'other' and stipulate 'mobile'. On page three Your description of the installation must include the container identification number. All tests on the installation must be done and recorded. No tests are done and recorded pertaining to the supply. A temp supply is connected to do tests on the installation itself. Page 4 is completed as per a new installation.
                  • SeanM
                    • Mar 2018
                    • 120
                    #114
                    Morning Sparks
                    Thank you so much for this insight, it makes a lot of sense and I am more comfortable.
                    This would be similar to a compliance for a caravan I would image.
                    • SeanM
                      • Mar 2018
                      • 120
                      #115
                      I have com across a few installations were the 'electrician's' have come up with ways to by-pass the compliance!
                      The most recent was were they put a sub DB in and feed it from a socket outlet and passed the installation as they said it was not part of the installation as it was feed from the socket outlet with a plug.
                      I informed the owner that this was not correct and that the compliance is there as a safe guard from previous people/animals that have been hurt and lessons we have learnt from incidents that have caused damage and harm (the regulations have been written in blood)
                      • Sparks
                        • Dec 2009
                        • 909
                        #116
                        Yes SeanM , a caravan would get a similar COC if it has a 220V installation. A Sub-DB may not be fed from a socket outlet is correct.
                        • SeanM
                          • Mar 2018
                          • 120
                          #117
                          Motors/pumps to be on an earth leakage yes/no, I can find no-where in the regulations where it requires a motor to be on an earth leakage.
                          Any comments?
                            • 22820
                            #118
                            Read section 7.2.4.4 Water Pumps of SANS 10142-1.
                              • 1490
                              #119
                              Section 7 is to do with swimming pools , paddling pools , ornamental pools , spas and fountains - The ELU requirement comes into play
                              Section 6 deals with fixed appliance and 6.16.5 with regards to Motors - which does not require ELU protection but you need to check the application you are looking at against- 6.7.1 in particular 6.7.1.2
                              • SeanM
                                • Mar 2018
                                • 120
                                #120
                                Thank you DaveA and GCE, I understand water pumps being on an earth leakage I would of thought that all motors should be. This would be my personal preference but I suppose I cant enforce it if the regulations don't call for it.
