Incoming supply
  • Leonsparky
    • Aug 2016
    • 17
    Incoming supply
    Hi, can someone please explain the incoming supplies (TNS, TNC-S etc.)to me. I did study them in installation rules, but struggle to understand it fully.
  • ACEsterhuizen
    • Mar 2012
    • 165
    Maybe this will help.
    • markthespark
      • Jul 2015
      • 52
      In your reg manual SANS 10142-1 Annex M gives quite clear indication of the different earthing systems. The best wait to understand them better is to take your manual with you to each site and then visually check the system against the manual. It has helped me a great deal!Soon you will easily be able to identify the system you are inspecting.
      " I'd always rather be on the golf course!! "
        If you're unsure by looking at the supply then perform a PEFC and a PSCC test on the supply at origin and if the two results are identical it's almost certainly a TN-C-S arrangement.
