Electrical Installation Costing
  • shnzimande@hotmail.com
    • May 2017
    • 6
    [Question] Electrical Installation Costing
    I'd like get help regarding the costing of electrical installation.
    Like how much is to install the below. All component are flush mount except geyser isolator. Thanks in advance
    DB single phase
    DB three phase
    Socket outlet
    Lighting point -does the price differ for concrete slab/ ceiling mount?
    Light switch
    Cooker point
    Geyser point
    COC
    Sent from my iPad using Tapatalk
    You'd need to do your own quoting exercise I'm afraid. There's nowhere near enough info for anyone else to even take a stab at it.
      • 22810
      If you're a member of the ECA (SA), among the benefits is access to the ECA Schedule of Rates - a spreadsheet that helps with per point pricing.
      I say "helps" because essentially while the formula structure is in place, it's populated with "example" data - you need to input your own figures before you'll get an accurate result.
      So if you are a member, contact the ECA.
      If you're not a member yet - time to join, perhaps?
