Conductor identification
  • Gtfast
    • Apr 2016
    • 78
    Hi all.
    The regs state that for multi core cables one can apply insulation tape wound more than once on the ends of the conductor for identification purposes.
    Can one use a black conductor as a live and indicate this by placing red insulation tape on the ends .Can this be done with any colour in the multi core cable .
    Trying to get it right.
    Sent from my HUAWEI VNS-L31 using Tapatalk
    If it's in a control panel or internal wiring of a machine then yes. If it's in a DB then I'm not sure. There was a discussion about wiring colours in this thread although I doubt it will clarify an answer for you.
    • Gtfast
      • Apr 2016
      • 78
      Thanks Andy.
      I was wondering if using twin and earth( red black and earth ).
      In a lighting circuit at the switch box using red supply into the switch and the black with red insulation tape on the ends from the switch to lamps.
      • Gtfast
        • Apr 2016
        • 78
        The circuit having the twin and earth in 20mm conduit .
          • 1473
          I would say yes - The definition of multi core cable is a cable that contains at least 2 cores ( 3.8.5 pg 34)
          Personally prefer heat shrink as a marker
          • Gtfast
            • Apr 2016
            • 78
            Thanks GCE
            With you on that one.
