Gas Stove Consumption : Oven
  • kevvie
    • May 2014
    • 32
    [Question] Gas Stove Consumption : Oven
    Hi all,
    I've got a gas stove, I use it a lot during the week. I usually get a 9kg bottle. Now I need to work out how much gas the oven, not top burners, uses on highest setting per hour. I have no clue how to calculate.
    Bottle:
    LPG Gas 9kg @ R380 per bottle
    Stove info on the label:
    Gas Supply 2.8Kpa
    Design consumption: 415g/h
    Loading Heat 13800w
    Heat Load: Burner 0.88mm and 2700w (on the oven section of the sticker back of stove)
    Please come to my rescue.
  • smithers
    • Sep 2012
    • 58
    you can try this link
    Welcome to the ultimate kVA Calculator, your go-to tool for seamlessly converting kilovolt-amperes (kVA) to kilowatts (kW) and vice versa. This essential utility is designed for professionals and DIY enthusiasts alike, providing accurate and quick conversions for all your power needs. Simply input your values and let the calculator handle the rest, ensuring you get precise results every time. Whether you're working on an industrial project, setting up a home generator, or just curious about power ratings, this kVA Calculator is tailored to meet your requirements. The user-friendly interface makes it easy to navigate and perform conversions in seconds, saving you time and effort. No more manual calculations or guesswork�our kVA Calculator is here to simplify your tasks. Trust in its reliability and efficiency to give you the exact numbers you need for any application. Start converting today and experience the convenience of having an accurate power conversion tool at your fingertips.
    • AmithS
      • Oct 2008
      • 1520
      Not sure how these calcs work.
      Wouldn't it be 9kg divide by Design consumption: 415g/h = 21.69 hours of usage
        Trying to calculate the gas consumption from the heat output stated on the oven is going to be hit and miss. The oven will have a modulated gas valve which is fully open when the oven temperature is below the set temperature but it will close when the oven gets hot enough so the consumption is not a constant. Best way would be to physically weigh the gas bottle before and after you use the oven for an hour or two.
