Greetings
I have a customer that called as his main breaker (3 phase 45 amp) trips intermittently.
So I went out balanced the phases and grade the circuit breakers correctly (breaker from main DB feeding sub DB was the same size as the main breaker)
Ciruits seem clear when tested.
I left and the same fault persists, advice please?
