Is it a must for Registered person to be registered as Electrical Contractor
  • Eagle
    • Oct 2019
    • 3
    Hi all,
    All the articles that I've read regarding the subjected title is still confusing;
    * Question: Is it a necessary for i Registered Person , e.g. Installation Electrician to be also registered as a electrical contractor?
    Kind regards,
    • 22812
    Perhaps you are getting confused because they are two different things, with a different role in the "ecosystem".
    An electrical contractor providing electrical contracting services must register as an electrical contractor.
    A registered electrical contractor must have at least one registered person active within the entity, as the sole proprietor, owner, director or employee.
    By my understanding this doesn't prevent a registered person from being employed by a company and not being registered as an electrical contractor in their personal capacity.
    They could also be employed by a factory, for example, where they only work on the electrical installation of their employer - which would not require registration as an electrical contractor... unless they were employed as an "independent contractor"...
    • Eagle
      • Oct 2019
      • 3
      Thank you Dave for the clarification. One last question; if you buy CoC forms from e.g. ECASA you need to provide you're registration as electrical contractor and not as a registered person?
      Kind regards,
        • 22812
        Correct - although the registered person on record as associated with the electrical contractor is also noted.
        Which raises a thought...
        In the situation where the registered person is working only on the electrical installation of their employer in the factory example I gave above - how is a CoC issued on that work?
        • Eagle
          • Oct 2019
          • 3
          Your clarification understood; in essence my second question attributed to why the first one was asked, but none the less your clarifications assisted me,....Much appreciated.
