Home automation
    Home automation
    I have been tinkering with some home automation...i am glad i didnt jump in with both feet...man there are a lot of options.
    So what i plan to do is go through the process set by step....learn as i go.
    Starting with the power supply ...no power no automation.
    What do we need to start... firstly we need to decide what we are going to connect to the circuit and how long will it run the system
    What are we gona need.
    A solar panel
    An inverter (pure sine wave)
    A battery or 2
    A circuit with blue dedicated plugs for the essential services only.
    the next step is to decide what is going to be regarded as essential services...so that we can decide on the power requirements
    The gate...which has a battery backup (but will also be on the circuit for additional backup)
    The garage Door (also has a backup battery ...but because the motor is run from the battery...it just needs a charge.)
    The adsl/fibre router.
    The alarm system (also has a backup battery ...so just power to the charger will be required.)
    The outside security lights will also be on the dedicated circuit.
    The CCTV system (no backup battery at this point)
    The TV and lite box.
    An led light in each room which can be activated via the alarm app...(controlled via a central relay system...which can be manually bypassed if the system fails)
    Door locks which will also have dead bolts which can be manually opened with a key.
    All the lights around the house will be operated via the alarm PIR sensors and day/night sensors.
    Things i need to take into consideration:
    The location of the system to prevent long cable runs.
    Roof space and heat... I am considering building a small room/cabinet in the ceiling space to house all the equipment ...taking into account the 50 temp at midday...so thermal insulation around the space... then ventilation.
    type of equipment to use...for example do i just stick to a standard router or do i split it : a dedicated router - switches/poe switches - WiFi access points etc
    Time to go to work ...to be continued.
    Some of the biggest challenges will be trying to find SABS certified equipment.
    Next step... automation
    Do i start small and learn basic C++ or do i learn python and go raspberry pi... looking at cost and capabilities... arduino has a massive library...so it might be easy to just wing it and copy as i need.
      Each room will have a low profile box in a practical location ...containing relays and equipment required for the home automation...you will be able to access the junction box from the roof space or the room below.
      The LED on the box will also be fed from the (blue) dedicated circuit.
      The box will be hinged so that it can suspend from the ceiling and all the component will be accessible ...the reason for this... so that you dont have to climb in the roof every time you need to check components or carry out test.
        • 1763
        Hi Ians
        Following this post with interest.
        Please keep us informed as you progress.
        Thanks in advance.
        Derek
          Are you going to fit them Google / Amazon / Apple / Facebook boxes that listen to everything you say and report it to their respective human PERVs.....?
          I am not connecting anything in my house to the internet that can automatically transmit voice or video. All my PCs and Android devices have very very serious firewalls on them.
            No voice activated devices or cctv inside the house.
            However every device (phone...tablet etc) has a camera and mic... after watching a few videos on hacking... you are a fool if you think nobody has access to your devices ... even worse these wi fi cameras people use as kiddie monitors etc.
              I have been putting some thought into the area around the house ...especially the windows we leave open at night... i have been renovating old houses which we strip completely and i mean completely ...i have a pile of old alarm systems which i have figued out how to default and program... I am going to use one of the systems to monitor movement outside my windows... it will not be connected to the alarm company ...just a buzzer which will sound if there is any movement...for the cost of a couple of rolls of 6 pair alarm wire... sorted.
              The camera system is up and running... connected to the network... so cool ...instead of having to go look at the monitor to see what is happening around the house... every device in the house has access to the cameras... now when i sit in my office ...i dont have to get up to go open the gate for the staff in the morning... i can be sitting on my porcelain throne or anywhere on the property... open the gate from the device while viewing the cameras and make sure the dogs dont run out the gate.
                Just in case you think you have nothing to worry about with regards to personal information... watch the interviews with Edward Snowden ...you think your phone is switched off in a cupboard.
                After watching these interviews ...you gona feel like there is a stalker watching your house... but in reality they are siting right next to you.
                After watching these interviews... do you still want a cheap R299 wifi camera watching your new born ...recording everytime your wife goes through in the early hours of the mornings to pop out her breasts to feed the little person... ... google connect... siri ... alexa recording every single "what you think is private conversations" in your own home... just stop take a 2 second break from all your devices and think about it.
                With all this info in mind ...we can continue with the design process.
                • Adriaan.S
                  • Nov 2016
                  • 3
                  Hi ians, why not use smaller PLC like Siemens LOGO 8 or even S7-1200? https://www.youtube.com/watch?v=ZCEZnr3cG8g
                    Thanks will look into it... i have a mate who works for Siemens ...and he works in automation ... i needed a VSD a couple of weeks ago ...in the past the starting price was around R4k now you you can pick them up for a faction of that price.
                    Just a heads up for anyone following this thread... i am learning and building as i go... any suggestions for easier cheaper methods would be appreciated.
                      So i bought a sonoff basic ...hooked it up and tried to link a 433 remote... my good friend google displayed a ton of sonoff setups etc... however i learnt that the sonoff basic cannot link up to a 433 remote unless you buy the sonoff bridge which cost just under double the price... so we are back to the IDS X 64 system for remote switching.. .thank goodness there are relay expander cards.
                      So you may be asking why a sonoff and a 403/433 remote... the answer is simple... it can be a mission having to take out the phone (me being as blind as a bat) every time you want to switch all the security lights on/off at 3 am in the morning ...also if i need to light up my street like a stadium (as i do with my 1500 watt halogen flood light) i dont want to be fumbling with glasses and phone... 1 button booom all the lights on ... which also works as a silent panic button if held in for 3 seconds... you might also ask why silent... after chatting to a women who was being dragged around the house by her hair while being punched and kicked by the home terrorist as the siren was making a loud noise... when they decided to go back and beat her again while they ransacked the house ...this time the alarm was silent and they didnt beat her up as much ...and because they didnt know the panic had been activated they took their time and got caught in the act.
                      This is why this home automation thing is going to be a lot of trial and error... the goal is to build this system at the cheapest possible price trying to integrate the alarm...cctv and security lights using the least amount of different platforms.
                      I have also just collected point to point outdoor wireless units... setup and ready to test... gona try them out on a site where i am working... had no idea what i was looking for ...but after a couple hours with my good friend google and youtube ...i learnt enough to understand the difference between the various options available... i went with the 5.8 option...because as we know 2.4 is pretty populated in most areas... i am going use one as an access point then going to connect 3 or 4 units on other properties in close proximity ...which we cant just run a cable over the fence ... taking the cost to trench... lay a pipe and pull in cabling ...it works out way cheaper for the customer... as opposed to my home project... cables work out cheaper for me personally and i get to install power and data to each point.
                      Still deciding if i am gona go cheap and use gum poles sealed with old engine oil or galv poles around the garden... galv pole just look out of place... gums poles would fit in better.. soaked in old engine oil or a day or 2 they should last 100 years... yeah i know the environment and all that ...research indicates that the poison in the pole treatment is far worse than the engine oil... looking at my treated fencing which is falling apart after 9 years.
                      • Adriaan.S
                        • Nov 2016
                        • 3
                        Hi Ians, if I can give my 2 cents I would look at a central controller. I know you are looking a lot at cost but I believe at the end of the day a cenral controller like a Siemens LOGO or other PLC will save you money in the end. Instead of using your sonoff remote to switch only the lights rather use it as an input to your controller and connect the lights as an output. Now you can also connect your alarm as an input and you have the option to program your controller to switch on the lights either by pushing the remote or when the alarm is triggered. You can also give an output to open the gate once the alarm is triggered so the security company can have immediate access to your premises. PLC's can also save you a lot if you look at the money you have to pay for building a circuit i.e relays, timers etc as this is all incorporated in the PLC and it is also simple to change the configuration by altering the program. Hope you find it useful.
