Ip rating.
  • Gtfast
    • Apr 2016
    • 78
    Ip rating.
    Hi All
    Does anyone know the IP rating of a 20 mm pvc round box normally used for conduit work in the ceiling. Is this box considered weather proof.
    Sent from my ANE-LX1 using Tapatalk
    • 4927
    If it doesn't have a manufacturers spec sheet that states the IP rating I'd guess you'd have to treat it as being unrated. Realistically I'd probably class it as IP44 if incoming conduits were glued and if the lid was a snug fit but I wouldn't consider it fit for external use where it's in the weather, also it's doubtful it would be UV stable.
    • Gtfast
      • Apr 2016
      • 78
      With you.
      Thanks for the input Andy.
