alternate supplies
    alternate supplies
    Installing DC cabling from batteries or solar power in plastic or in metal trunking or steel cable tray?
    Installing open DC cabling from sloar panels in a closed trunking or exposed on a steel cable tray, taking heat and UV and all the other things into account.
    The one problem with DC is that if there is a fault, the arcing will continue burning until there is a break in the supply.
    See this site for examples of what you should NOT do, it is an eye opener
    Solar fires – DC arc faults
