Was watching a video on youtube of the guys over in the uk doing tests on houses and such. I see something very nice which we will probably never get in South Africa. A plug top that can take test leads ! Funny enough I made my own contraption a few years ago and this made me go dig it up again
Something intristing
As unsafe as this thing looks it is still not very easy to reach life parts by just plugging it in and out normally.
Sent from my iPhone using Tapatalk -
major tech had a plug top with sockets to insert test leads ... i did a search for it ... but couldnt find it ... I will check the mt number and get back to you.
I use it with the mt 250 to do voltage recordings on socket outlets.
edit .... MTL-20 socket adaptor.Comments are based on opinion...not always facts....that's why people use an alias.Comment
Kewtech R2 4mm Socket adapter The Kewtech R2 Socket adapter is an essential accessory for fast testing without removing the UK wall socket outlet. It saves time and is safe. The Kewcheck R2 enables good connection to the electrical wiring installation with 4mm test probes without taking the 3 pin socket off the wall. It facilitates R2 and R1 + R2 measurements as well as voltage detection at wall socket outlets. With the phase and earth conductor linked at the distribution board, your continuity tester probes are placed in the phase (R1) and (R2) 4mm sockets on the KewCheck R2 and then a reading is taken before moving onto the next socket. The Kewtech Kewcheck R2 Socket Test Adapter is suitable for a wide range of Continuity testers and test meters from Kewtech, Megger, Robin, Metrel, DiLog, Alphatek and Seaward. Use the Kewtech R2 plug in test adapter to speed up periodic 17th edition testing and Part P testing of UK electrical installations.
Major tech (SA) use to sell a socket adaptor which looks similar to this ... i bought a couple of them about 15 years ago.Comments are based on opinion...not always facts....that's why people use an alias.Comment
It's available from RS Components but it's double the price...https://za.rs-online.com/web/c/test-...r-accessories/https://www.test-meter.co.uk/kewtech-r2-socket-adaptor/
Major tech (SA) use to sell a socket adaptor which looks similar to this ... i bought a couple of them about 15 years ago._______________________________________________
Good news ... I contacted major tech today and enquired about the MTL 20 ... they have 600 in stock ... List price R109 ex vat (you will get it cheaper from a wholesaler.)
They are not advertised anywhere ... you will not find one on thier website or in thier new catalogs ... but they do have stock in JHB.
As i am sure some of you have noticed I am not a huge fan of major tech M series products ... but I give this MTL 20 10/10 ... an brilliant product which makes testing a lot easier ... you can either push a standard probe into th unit or remove the point and plug in the cable only.
I have one on site at the moment with the MT 250 plugged into it.Comments are based on opinion...not always facts....that's why people use an alias.Comment
