12V lifePO4 battery packs
    Anyone know of a supplier of these battery components for sale in SA.
    I am looking for a the parts to make up myself ... it must have all the components.
    The PCB
    The batteries
    A BMS
    A charger.
    I want to be able to expand the battery capacity ... starting at 10 am/hr going up to around 50 amp/hr or even higher if I can get it.
    Originally the supplier was on 16 VAC ... however ... this no longer applies ... 230 VAC in and 12 VDC out ... it would be even better if I can parallel the batteries to create 24 or 48 VAC for POE applications.
    The plan is to mount all the components inside an enclosure with other PCB's so it doesnt have to be in a battery case.
  • moldie
    • Aug 2021
    Contact Lithium Batteries South Africa for premium LiFePO4 batteries and expert energy solutions.
      They have the same problem everyone else in the country is experiencing ... no stock thanks to the port crisis ... it seems its just another tender story ( Stories surfacing about Gijima holdings)
        Read the latest news, related to tenders and business in South Africa from OnlineTenders.
        • BriggTrim
          • Aug 2021
          Hi....I work in boat expanding on the plan side, explicitly electrical. I'm working with an organization on a marine electrical drive framework and have done a great deal of work planning in Lithium Ion battery frameworks in top of the line boats.
          For those of you who don't know, ABYC delivered TE-13 Lithium Ion Batteries in July of this current year. It consumed a large chunk of the day to arrive on the grounds that it is a confounded subject. I can disclose to you that this is a work in progress and there will be changes coming. There are a ton of wellbeing issues to consider. In contrast to your electric vehicle, you can't stop out and about and get out in case there is an issue like fire, and indeed, fires do occur.
          Part of what you are paying for with these "canned frameworks" is a little piece of the designing time that went into creating them as protected as possible today. Assuming that has no worth to you, do what you will.
            • 3517
            Maybe you need to look at another supplier.
            I saw a battery pack designed with a liquid inside which would prevent lithium batteries catching fire and was specifically designed for electric aircraft use. Can not remember if it was a German company.
            Anyway here is a link that may set you on the right path
            With Ultralight Lithium-Sulfur Batteries, Electric Airplanes Could Finally Take Off
