Coc
  • Stech
    • Sep 2021
    [Question] Coc
    Hi guys, I am new to this forum and newly registered installation electrician. Need to know if I add a new plug circuit to an existing installation, do I test the entire DB for the COC?
    And that where the fight started
      • 1489
      I would take the necessary readings at the DB , loop voltage etc , to enable completion of the form . Under comments I would state new socket from existing socket circuit , or from where ever you took it, and state that the coc is only for the one socket.
      If I saw obvious incorrect wiring , I would also state under comments that " faults were observed , Have notified homeowner that a inspection is recommend " or alternatively " have supplied quotation to homeowner to carry out a full inspection due to faults observed on the installation of a new socket "
      At least that way if anybody tries to come back at you your ass is covered.
      Make sure you keep copies of COC's issued for record purposes
      • Stech
        • Sep 2021
        OK thanks
