DB as a wire way.
  • Gtfast
    • Apr 2016
    • 78
    DB as a wire way.
    Hi all
    Good new year to you all.
    Two questions.
    I have checked the regs.
    - I cannot find anything. Is it allowed to use a DB as a wire way for one of its circuits. The circuit will run in and then out the DB with surfix.
    -Is it allowed to cut trunking into DB's sso and light switch boxes instead of using Glands.
    Sent from my MAR-LX1A using Tapatalk
    • 1765
    Originally posted by Gtfast
    Hi all
    Two questions.
    Good morning brother.
    I cannot see a problem with either.
    1. As long as the supply to that circuit originates from that db, I don't see it being a problem.
    2. As long as the trunking protrudes into the enclosure, that's what I've been doing for years. It's a lot neater than ending the trunking 15cm from
    the enclosure and having the bare cable enter the enclosure through a gland.
    Tip: For small trunking ( yb1,2,3, or 4 ) we drill a round hole big enough for the trunking to fit and seal with contractors acrylic afterwards.
    Quicker and easier than trying to cut a square or rectangular hole to accomodate the trunking.
    Peace out ... Derek Stuart
    • Gtfast
      • Apr 2016
      • 78
      Hi Derlyn
      Agreed
      Thank you.
      Go well.
