Standby lights for site
    I have tried and tested many many lights for site work, todate I have only found one light that I would recommend, its could do with some improvements.
    I am sure you all know by now which light I would recommend - The magneto, you can find then cheaper if you look around, just dont mix up the R129 one with this one below.
    Pro's
    1/ Backup time, it last the entire day on site.
    2/ 2 brightness settings, to save battery power.
    3/ Bright enough for site work, especially in the roof space.
    4/ Compact enough to go in the tool bag.
    5/ No magnet to stick it to the DB door or inside the DB.
    Cons
    1/ Battery lifespan, it only last about a year, then you need to replace the battery, you can buy replacement batteries for about R120.
    2/ Battery fails if left for an extended period of time.
    If this light had a lithium battery I would invest in one for each room in my house and another 6 for site work. I have thought of making up my own lithium back.
    I am busy making up a site lights and home backup lights, using the 7 amp lithium battery and 12 volt strip lights. I need to find affrdable lithium battery packs with a PCB to charge the battery and under voltage and polarity protection.
    If I can get that right I have a winner which will replace the magneto light. The price is not the concern, I want something to last, not fail if left for a couple of months.
  • Dylboy
    • Jun 2020
    • 777
    Those lights rock!
    Found an even smaller one at Leroy that fits in the tool bag very well.
    Also thought of those ones and then a stand to create some task lighting in areas and position it etc.
    The Lithium pack would be very cool
      • 1761
      Those lights are great.
      I've installed them as emergency outdoor lighting in enclosures with transparent covers.
      They come on automatically with loadshedding. Been up for about 2 years and still working perfectly.
