Switch directly eskom vis DB
  • riyaz
    • Aug 2022
    • 4
    [Question] Switch directly eskom vis DB
    HI,
    Advise please.
    I f you install a plug that connects directly to the DB via C/B. Can I use a 4mm wire with C/B 40A and the plug will be 32A. I need to use for portable welding.
    Riyaz
    • 1495
    4sqmm wire is rated at 32Amps so if you using 40Amp CB then it should be 6sqmm.
    The plug would need to be "welding socket " type rated at 32 Amp and on Earth leakage
    • riyaz
      • Aug 2022
      • 4
