Something I have never really bothered about, if the machine is supplied with a the cable attached.
Lets say I install a 32 triple pole isolator on the wall, connected to a 32 amp D curve breaker in the main DB, fed from a 4 mm 4 core+E surfix 30 metres away.
The machine arrives and it has a 1.5mmx 5 core cabtyre hanging out the machine for connection to the isolator.
Can you connect the cabtyre directly to the isolator ?
