MIE required to sign off battery bank?
  • mnisi3538@gmail.com
    • Jan 2023
    • 12
    [Question] MIE required to sign off battery bank?
    Good day all.
    If I may ask installation of a solar system it need master installation certificate or it fall under a specialized installation because of the batteries since it use chemicals. I m referring to the issuing of coc. It need master installation electrician (MIE) to issue COC because of the batteries.
    • 22810
    Asked and answered in this question on solar system.
      • Jan 2023
      • 12
      Not exactly, can you elaborate further please dave.
        • 22810
        If the battery bank is such that it is deemed a hazardous location, then it will be need to be signed off by an MIE. The main issue as I understand it is the gasses given off by the batteries. The prime example would be a lead acid battery bank where you could accumulate dangerous levels of hydrogen.
          • Jan 2023
          • 12
          Thanks alot Dave.
            Mie required to sign off a battery bank, its like asking what size earth wire should I use for an electrical installation?
            You would need to give more details, it is not a simple yes/no answer. I wish it was, there seems to be a lot of confusion about batteries and safe installation location.
