What do you guys do? I have mentioned this in another thread so sorry if i repeat myself
I know every electrical installation is supposed to have an existing CoC (yeah right....) - but they usually don't.
Say you do a small job, add a socket for example, to an existing circuit i think its fair to say you can do a CoC for that socket. All you can do its inspect and test that circuit to the best of your ability. I cannot and do not believe you are supposed to CoC the whole house just to that job (its just not realistic)
Then you do a bigger job (a solar install in my case). Do the basic checks and all checks out fine - this is a 6 bed R8 million house by the way.
Do the solar install in 2 long days and would welcome any AIA inspector or ECA guy to check it.
Comes to testing time and we start finding things wrong with the existing.
I spend 2 days (well more than that actually) fixing little bits and pieces and eventually enough is enough.
Advise client that so far we have found item a,b, c and d non compliant - nothing dangerous just lots of little things.
With most of our solar installs there is an existing CoC so we do a supplementary CoC to the existing (even though most we see are BS) we advise the client as such and they ignore it.
Any new works require a CoC (Agree) but we must do a CoC on teh whole building if we install solar to an existing installation if there is no CoC (disagree). Its just not realistic
How can we MAKE client fix non compliant installations? DOL says there must be a CoC but we can't issue because its not compliant.
Where do we stand? Can't make them pay for non compliant items?
I have chosen, until now, to only do new installs because I don't like adding to other people kak but since a lot of my customers got crappy solar installs I started do Solar again (was doing solar for years in the UK, Oz and New zealand before coming here) becaus ethe demand was there but that means I'm adding to existing.
I know what is supposed to happen but thsi is SA and its just not.
