Hi all,
I'm new to the group, I have a electrical problem at my house, I will give you a bit of history and will try try to keep it short.
My problem started with an underground cable fault which was tripping at the municipal meter box outside my property, a contractor was assigned to fix the problem, a "thumper fault locator" was called in and the cable was bridged with aluminum cable ? My problem now is that my earth leakage is tripping on my DB precisely every two hours, 33 minutes past the hour, 5-33, 7-33 9-33 etc., I actually stand in front of the DB ready to reset the earth leakage which stays up till exactly two hours time, this has been constant for the last 3 days. this problem was not there before the work was carried out on the supply cable I'm waiting for the contractor to return to look at it but I was wondering if anyone could shed some light on this problem ??
Regards
magron
Regards
magron
