Was wondering, is it at all possible to tamper with the db board wiring to 'slow down' a prepaid sub-meter. I suspect one of my tenants had some fiddling done as readings ar suddenly much lower than usual consumption and nothing has changed ito what is plugged in/used in the premises.
Distribution Board tampering
Tags: None
The easy answer is yes, it can happen, but there can also be other reasons for the change in consumption.
I was at a house recently that had a changeover on the prepaid. Part of the month they run on the prepaid meter, and part of the month they don't.
Also, the user might have been gone on holiday, hence a lower reading. A constant lower reading might be due to tampering or a change in consumption habits.
I have clients that have a control meter before the prepaid meter. They compare the control meter units with the prepaid meter units and can easily see if something is fishy.Comment
The most common monkey business is to put a bridge piece across the input and output of the meter with a wire so some of the load goes through the meter and some through the bridge.
Easy to detect.
Switch on a light. Turn the meter off and if the light is still on, the meter has been bridged.Comment
Ahhh yes ok, seen that before! Newly installed sub meter, client calls to say they only paid R60 in 2months and had just moved in!
Went to go look and a nice little 2.5mm bridging the line in and out.
Easy to pick up visually but I was thinking maybe something else non visible maybe happens to slow It down
Sent from my CPH2197 using TapatalkComment
The old wheel meters had a bridge, if you remove it the meter stop working. One week on and one week off saves you half your bill. With the new electronic meters it is a bit more difficultComment
