Day/night switch for a bulkhead LED
    I am looking for a day/night switch that fits inside the fitting with with a hole on the side of a fitting.
    There is one supplied by most wholesaler, with a notice attached (NOT SUITABLE FOR LED LIGHTS), yet they are sold with led lights
    Any suggestions?
    • 1761
    Why not just screw in a day/night es led lamp ?
      Because the light fitting is a special bulkhead and doesn't use an ES lampholder
      In fact it is a really awesome bulkhead,I have been using for a while now, you can change the colour of the light from w/w-DL-CW.
      These things are supper bright and IP 65, so they are ideal for coastal applications.
      Specialized 3-in-1 CCT switching allows the user to change from 3000K, to 4000K to 6500K BMTC SMD2835 LED chips give high efficiency and an excellent lumen maintenance. Wide voltage (180 – 277Vac) input, EMC approved and flicker-free UV stabilized housing prevents the fitting from degradation 35,000 or 50,000 hours available
      Any suggestions?
        • 1761
        Ok. Those Radiant 351(long neck) and 352 (short neck) will work on those fittings even although they are marked " not for led use".
        They will not work on a 6W or 9W lamp because of the low current drawn by those lamps
        However
        I see that bulkhead of yours is 25W so that day/night switch should work fine.
          That's what I thought, so I went to my local wholesaler who sells anything to anyone, installed it and it didnt work. I have a feeling the unit they sold me was faulty, returned it and busy sourcing another one to try it.
          I had a look at AC/DC express, they have one which cost more than the light and PEC combined, we will pass on that unit.
          However
            Tell us more, from my understanding, a day/night switch has a sensor to detect light and a relay for switching on/off.
            The relay will be sized according to the max switching load rating, some are rated to 6 amp and others to 16 amps.
            Educate me on why an LED cannot be used, because of the driver inrush current?
            However
