If I understand you correctly. you talking about the earth wire from the isolator to the geyser and from the bond strap to the geyser. I have been doing for as long as I can remember, the only reason we do it, to make it look nice.
Have I even had an issue with it causing a problem, not that I am aware of, some properties where I did the elctrical installations as far back as 1996, they still working, they all have coiled earth wires from the geyser to the isolator and to the bonding strap, then a copper strap from hot to cold.
But hey that is just me, maybe someone can post pictures of burnt wires or a fire caused by this practice.
Another place where you will see coiled earth wires, old generator installations that we did back in 2008/9. All our generator installations have coiled earth wires, to make it look pretty.
I am not aware of any of those generators bursting into flames, caused by a 1 m long coil of earth wire.
Some will say you must keep the earth wire as straight as possible. I have seen electrical equipment hit by lightning and tell you a short piece of earth wire isnt going to make much difference.
