This is where I got the information... one of the many Sunsynk training documents I have been reading since the beginning of 2022.
If you link 2 strings in parallel, they must be identical, but you can mix panels between MPPT's.
Copy and paste:
WARNING:
If the voltage is too high on the MPPT, you can burn out the front-end. DC to DC converter damaging also invalidates your warranty. Keep your Voc below 450V.
Regardless of the power of the solar panel, the inverter will only draw what it needs (basic ohms law).
Please refer to our training manual part one. When wiring to strings in parallel, please make sure the strings have identical power, identical size, and identical manufacturer. Do not mix panels if one string is only 8 panels and the other 9. This will create an imbalance and cause major efficiency losses. However, you can mix panels between the MPPTs since both inputs work independently.
Copy and paste:
WARNING:
