So you do an inspection for COC.
You find an aircon circuit wired with 1.5mm wire protected by a 20A breaker. Problem.
Now you have 2 options.
A. Rewire the circuit with 2.5mm wire or B. Change the circuit breaker to 16A.
Using a clip on tester you measure the current drawn by the unit is 5.8A.
Would you quote to do A or B above and why ?
