electrical pictures
  • murdock
    • Oct 2007
    • 2346
    electrical pictures
    this pic is wiring inside trunking which are overhating.
  • murdock
    • Oct 2007
    • 2346
    an unbalanced load
    • murdock
      • Oct 2007
      • 2346
      checking for loose connections on terminals.
      • murdock
        • Oct 2007
        • 2346
        this was one of the first images i took when i was learning about emmisivity and reflective temperature
        • murdock
          • Oct 2007
          • 2346
          commissioning a machine making sure the temperature on the various components are set correctly
          • murdock
            • Oct 2007
            • 2346
            checking terminals
            • murdock
              • Oct 2007
              • 2346
              commisioning machine checking even temp. spread on the end product.
              • murdock
                • Oct 2007
                • 2346
                this was the first test run product ooops
                • murdock
                  • Oct 2007
                  • 2346
                  an infrared camera is not an x-ray machine...you cannot see through walls only the temperature of the wall...i ragged my neighbour that i was gona keep an eye on him and his activities inside his house
                  or an example is the trunking pic were the temp inside the trunking is hotter than the outside so the trunking heats up to the same temp as the wires inside making it possible to see there is a problem.
                    • 22812
                    That really is a useful tool, Murdock.
                    • murdock
                      • Oct 2007
                      • 2346
                      these are just a few of the applications i have used it for...i have also used it to check were my cooling problem was in my bakkie...game view...finding animals in a game reserve...checked a motor vehicle which had a problem with one cylinder not firing properly...the oppotunities are only restricted by my imagination.
                      • murdock
                        • Oct 2007
                        • 2346
                        hyena in the game reserve...it was pitch black you couldnt see your hand in front of your face
