Fire at my own place.
So I foolishly went on holiday and let go of the reins for 3 weeks....
Day one and my camera system (which has been working faultlessly for 6 years) fails.
There was lightning and one neighbour reported having his DEYE inverter fail (everything in place - AC surges, DC Surges, 16mm Earth spike from panel etc), other neighbour lost all there power supplies (gate, alarm, intercom, lap top, desk top all popped) and another neighbour lost all his routers and internet equipment.
3 days later I get a call from my neighbour and my house is on fire - which is nice to know when you are on holiday.
My house is done - to the letter.
I use it as a show house for clients for solar and for small home automation systems (sonoff and shelly etc)
When I bought the house I did the CoC for the owner. I basically disconnected everything (as it was VIR and I knew I would be rewiring front to back) and just installed a temp board with one socket.
I found at that point there was no incoming earth (TN-S earth system) and after 3 months of back and forth with the owner, the bank and the municipality I finally got someone witha brain to come out with a loop tester to say "You're right there is no incoming earth" at which point they bought out the boom arm and went up the pole and resolved the issue for me - both of us using our testers to confirm before and after readings. Before was around 6 ohms after was 0.8ohms.
Pictures were taken, I signed the CoC for a DB with one socket and it was sent to the bank.
2 years ago I installed my own solar (licensed electrician and Green card etc) and did a CoC for my insurance company - Earth reading was still good.
Right - back to the fire thing.
Now bear in mind the only thing that has changed on my istallation in 7 years is the addition of solar which tested out text book perfect.
3 days after the lightening stike my neighbour calls me whilst I'm enjoying a full English breakfast in London saying my board is on fire.
I managed to calm him down enough to switch off and put the fire out with an extinguisher I had at home - could have been a lot worse.
I got the only other electrician I trust to go around and make sure everything wqas isolated and safe. Firebrigade even inspected the roof to make sure nothing else was cooking.
Nothing is on in the house (as we were away) apart from power to the gate, and outside lights (fridges were off, TV etcwas off and all unplugged, geyser was off)
Anyway, I try and enjoy the rest of the holiday knowing there is no alarm, no cameras and no lights on my house.
I get back and arrange for the insurance assessor to come around. They had already sent some electrician round but I was not happy about anyone going around because then someone knows you are not there.
You know when you know you have done everything right - the install, if I say so myself, is a work of art. Loops into teh downlights all even, clipping eveny spaced, cover screws all line up the same way.
Like I said - I have used it to show case what we do to my clients.
I had the most in depth CoC ever with a reading for every point when I did the install with photos.
Found out that there was no incoming earth from Municipality. I did a video call with insurance companys technical guys - did a loop test whilst they watched to show no incoming earth again. I think the reading gave me a fault current of 19amps
Luckily I had used fire sealant where the trunking goes into the roof space so the fire was contained within the mains cupboard.
But it goes to show - even if you do the best you can you can still have issues through no fault of your own. You lose your fault protection due to there being no earth from municipality (which was there before)
I have been to 4 sites this year alone (3 of which I know there was a good earth there because I tested and signed the CoC's myself) and now there is no incoming earth.
On those 4 site I have had to deal municipality guys and not one knew what a loop tester was or when I showed the results of the test had the vaugest idea of what I was showing them.
I said to the assesor "how is surge arrestor going to work effectively if there is no earth? How is breaker going to operate within required times - if there is no earth?"
These kind of things are out of our hands and we rely on the, sorry but, uneducated, unskilled and not appropriately kitted up line workers.
On the plus side I am fully covered and I will putting it all back myself and my house will be getting repainted inside.
Just glad it was my house not a client.
Careful out there guys - it can happen. First time in 33 years as a sparks and it was own place.
