Another question, still related to the connections in a roof/enclosing it blah blah....
Open wiring is legal, not preferable but legal. How do you make joints on open wiring.....by using a porcelain screw. This joint then is not in a box/enclosure?, yet, the term "open wiring" in my view is the entire system, not just the two wires, but everything you would normally use for open wiring. So, open wiring joints are in free air....no enclosure.....although you cannot touch the live part with the STF.....it is in theory legal......therefore I deduce that a joint in a roof can be done with no enclosures as long as you use a porcelain screw??????? Whats wrong with this statement?
I just want to throw this into the mix: If you did a connection with a Hellerman Tyton Helecon connector block (which carries a ridiculous amount of approvals including SABS), then the wires are not exposed, you cannot touch the live parts wit a 2.5mm test rod, they are mechanically strong and you need a tool to remove them........
