Installation Rules-past papers.
  • Master Electrician
    • 28
    You wanted old exam papers. Paper 2.
    http://www.theforumsa.co.za/articles/IE-past-paper.pdf
    http://www.theforumsa.co.za/articles/P2-Apr07-IE.pdf
    http://www.theforumsa.co.za/articles/P2-Nov07-IE.pdf
    http://www.theforumsa.co.za/articles/P2-Aug09-IE.pdf
    Thanks to DaveA for doing the deed.
    My only desire for doing this, is to empower competent electricians.
    Guys, take your trade very seriously.
    It is regulated by law.
    Take the time to study the regulations.
    Write the exams.
    It's over to you.
    Note from Admin:
    Where to find the latest list of past papers.
    Over the years this thread has had many replies, and the list of past papers has been updated. Unfortunately this means that it has become difficult for newcomers to identify the best / latest list. So I'll try to keep this spot updated with the location of what seems to be the latest useful post listing past papers.
    Right now that seems to be here.
  • Maccie
    • Aug 2010
    • 14
    I am registering for paper 1 today.
    The lecturer, the people form department of education and the Technisa people all say the same thing, due to the volume of work, it is recommended to do one paper per tri-mester.
    Havind said that, I am also buying a pack of old exam paper 1's. If Dave could pm me a way to get them to him to put them up on the site I will send them.
    I can also send the syllabus showing excactly what is need to be learned for papers 1 and two as well as the masters installation syllabus.
    Thanks for the old 2nd papers
    • shuudeni
      • Sep 2010
      • 14
      I registered a week before, but guys is a bit hard to study here in Namibia. 1. No enough resources. 2. Work volume. 3. No syllabus of what i am expected to learn for paper 1 and 2. Is it possible for you guys to send me old paper 1 question paper(solved if possible) and the syllabus, just to lighten up my studies
      • mikilianis
        • Dec 2008
        • 124
        Installation Rules
        As I have mentioned before when I was preparing for the exams I was advised to know the definitions could be worth 30% then section 6 which deals with the design of a installation is covered in the first paper. Section 7 which is the practical side is dealt with in the second paper then get to know how to estimate loads, current carrying capacity's of cables,voltage drop that should get you 60% enough for a pass which is 50% or unless you are aiming for 100% good luck then again correct me if I am wrong I wrote in 94 things could of changed since then.
        Cheers Mike.
        • Maccie
          • Aug 2010
          • 14
          I have emailed Dave the syllabus as it is since august 2009.
          It has changed a lot with things like the electrical machinery act, the construction regulations, and the ohs act coming into it ( paper one). They have also included some other sans codes like handling of cables etc.
          Not all of the above just sections.
          BTW these can be downloaded for free from the department of labours website, I will post links a bit later or tommorrow if I get the time. Just make sure you get the latest ammendment.
          • shuudeni
            • Sep 2010
            • 14
            Pls post the syllabus. I registered for both papaers but for now I am only considering writting paper 1 now. Pls post the syllabus for paper 1. Its very hard to study here man, accross the boarder(Namibia).
            • Maccie
              • Aug 2010
              • 14
              This is a copy paste from the one I sent dave:
              4.1. SPECIFIC CONTENTS PAPER 1 (CODE: 11040412)
              4.1.1. Occupational Health and Safety Act, Act 85 of 1993
              Section 1, 8, 9, 10 and 22
              4.1.2 Occupational Health and Safety Act, Act 85 of 1993 - Electrical Installation Regulations
              Regulations 1 to 14
              4.1.3 Occupational Health and Safety Act, Act 85 of 1993 - Electrical Machinery Regulations
              Regulation 1, 3, 5, 6 and 11
              4.1.4 Occupational Health and Safety Act, Act 85 of 1993 - Construction Regulations
              Regulations 22
              4.1.5 SANS 10142-1:2008
              The wiring of premises Part 1: Low voltage installations
              Section 1 - Scope
              Section 2 - Normative references
              Section 3 - Definitions
              Section 4 - Compliance
              Section 5 - Fundamental requirements
              Section 7 - Special installations or locations
              Annexure D - Example of assessing estimated and connected load.
              Annexure F - Recommended bending of cables
              Annexure G - Examples of determining the conduit size required for single-core
              cables of different sizes.
              Annexure J - Explanation of IP ratings
              Annexure M - Electricity supply systems
              Annexure P - Authority for issuing a Certificate of Compliance
              Annexure Q - IEC symbols associated with switchgear
              4.1.6 SANS 10198-1:2004
              The selection, handling and installation of electric power cables of rating not
              exceeding 33 kV Part 1: Definitions and statutory requirements
              4.1.7 SANS 10198-2:2004
              exceeding 33 kV Part 2: Selection of cable type and methods of installation
              NOTE: No calculations will be asked on this standard
              4.1.8 SANS 10292:2001
              Earthing of low-voltage (LV) distribution systems
              TOTAL MARKS: 100
              NOTE as I said before the Ocuppational h&s docs can be downloaded from the Department of labours website.
              Here is a link:
              • shuudeni
                • Sep 2010
                • 14
                Thanks man. you are a realy life savior. Atleast now I know what to study man. Thanks again I will keep in touch.
                • shuudeni
                  • Sep 2010
                  • 14
                  Hi guys. I need paper 1 question papers for the year 2008. (NON-NATIONAL CERTIFICATE: INSTALLATION RULES). Your help will be much appriciated
                  • Maccie
                    • Aug 2010
                    • 14
                    The syllabus I posted was implemented in may 2009, with the first exam being august same year.
                    I went and fetched an exam pack from the college today, I will try and scan it in this weekend and send to dave. The papers I have start April 2003 and the last is 21 july 2010.
                    I am only going to send from august 2009 till the last one august 2010 ( 4 papers). They dont have answers tho, BUT It doesnt look like you will need them, a lot of true and false and fill in the blanks type questions.
                    One thing I am so happy about is that definitions is no longer 30 marks.
                    • Agega
                      • Oct 2010
                      Thank you very much for the post.I'm currently studying both papers and I'm writing in November this year.
                      • Gvtonder80
                        • Oct 2010
                        can any body perhaps email me the 1st paper for jun or jul 2010.pretty please?
                        • raj
                          • Oct 2010
                          hi guys. have completed my technicians diploma in 1984. been with Telkom for 15 yrs and then branched out in business since 1994. started a clothing factory (wired complete myself x4 2000msq ea)and excelled until 2004, when the industriy took a turn, shut down operation. Have since been doing various tenders and construction work and surviving.
                          Have done various maintanence projects wherein got insp. completed and c.o.c. by reg. contractor, but now would like to register and sign my own completions, where do i start ? -P1P2. Been to the training centres and "wow" they do as if i'm alien because of my age, all sorts of - must come in and spend a month 08h00-16h00.Cant this be studied at home and exams written or any exemptions given. give us some advice? plse
                          • shuudeni
                            • Sep 2010
                            • 14
                            Sup Man. You havent posted the question papers (paper1) as you promised.
                            • Maccie
                              • Aug 2010
                              • 14
                              Hi all Apologies for not posting the past papers.
                              My scanner has broken, so I cannot scan the ones I got at the tech, However I received a disc from my lecturer with all sorts of info, the Other sans codes are not on it (cables, lv earthing etc), but I do have a lot of old exam papers with answers for most.
                              I cannot upload them here or email to dave as they are large, they are scanned jpegs and each paper after I convert to PDF comes to around 2.3Mb.
                              Those of you that still need, please pm me on forums with an email address and I will gladly send you some, alternatively if someone knows of an ftp site I can upload to, I will also do that and link the paper downloads.
