SANS codes.
  • I Robot
    Administrator
    • 783
    SANS codes.
    I see the SANS codes are not available online.
    Would an online version of SANS 10125 be useful. I can see about loading them and keeping them up to date. It would also be searchable, which might prove useful.
    Any comments.
    All it takes for evil to flourish is for good men to stand by and do nothing.
  • Nicky
    • Jun 2006
    • 3
    Of course it would be useful! Absolutely! It would also be an excellent idea if you highlighted new regulations as soon as they are applicable.
    • Jacques#1
      • Oct 2009
      • 201
      ....Just make sure the one you post is not the version you pay for in the store ...it may upset a few guys up at SABS if you know what I mean.
      IJS Installations
        Any comments.
        How deep did you rummage? This is a link to a torrent file that looks promising, here's a few of the codes contained within;
        Edit; If you're not sure what to do with the torrent file send me a pm and I'll show you how.
        ACI-318-02 Building Code Requirements For Structural Concrete.pdf
        ANSI EASA Standard AR100-2001 Recommended Practice for the Repair of Rotating Electrical Apparatu.pdf
        Construction Standards for Small Vessels.pdf
        Gold Coast SS12_StandardSpecifications2006[1].pdf
        Haccp/9cfr417haccp.pdf
        International Building Code 2006.pdf
        ISO_9000'2000_An_A-Z_Guide.pdf
        ISO_9000_Quality_Systems_Handbook_4E.pdf
        LEED FAQ's.pdf
        LEED_CI_2.0 REFERENCE GUIDE/CI Scorecard.xls
        LEED_CI_v2.0_GUIDE.pdf
        LEED_EB_v2.0_GUIDE.pdf
        LEED_NC sample test.pdf
        LEED_NC_scorecard_version_2_2.xls
        LEED_NC_V2.2_GUIDE.pdf
        National Electrical Safety Code Handbook
        NEMA ICS 19 (2002).pdf
        Portable Oxy-Fuel Gas Systems For Welding (Australian Standards).pdf
        South Africa National Building Regulations SANS 10400
        SANS10086-1.pdf
        SANS10086-3.pdf
        SANS10089-2.pdf
        SANS10108.pdf
        SANS10123.pdf
        SANS10142-1(Amdt2).pdf
        SANS10142-1.pdf
        SANS10313.pdf
        SANS60079-0.pdf
        SANS60079-10.pdf
        SANS60079-19.pdf
        SANS61024-1-1.pdf
        SANS61024-1-2.pdf
        SANS61024-1.pdf
        SANS61241-1.pdf
        SANS61241-10.pdf
        SANS61241-4.pdf
        BY-LAWS RELATING TO ELECTRICITY SUPPLY.pdf
        coc for electrical installations.pdf
        CODE OF CONDUCT DESIGN AND CONSTRUCTION OF COLDSTORE.pdf
        ELECTRICITY BY-LAW, 20.pdf
        Emergency_lighting_Guidelines.doc
        HEATED TOWEL RAILS- INSTALLATION IN THE BATHROOM.pdf
        IEC600~1.PDF
        IEC600~2.PDF
        IEC600~3.PDF
        OCCUPATIONAL HEALTH AND ASFETY ACT.pdf
        Regulation - 2920 - OHS - Electrical Installation Regulation.doc
        2007 Edition 2 Induction motors Part 1 IEC requirements.pdf
        2007 Edition 1.4 Part 2 Low-voltage three-phase standard motors.pdf
        Guide for the design and performance of cage induction motors .pdf
        identification and classification of dangerous goods for transport.pdf
        SANS10142-1 Amendment No. 5.pdf
        SANS10142-1(Amdt3).pdf
        SANS10142-1(Amdt4).pdf
        The rewinding and refurbishing of rotating machines 3-phase.pdf
        SANS10~2.PDF
        Rewound and refurbished rotating electrical machines.pdf
        SANS60269-2(IECamdt2)SUPPLEMENTARY REQUIREMENTS FOR FUSES.pdf
        Surge Protection in Low Voltage Electrical Installations.pdf
        The RS-232 Standard .pdf
        • 123
          • 57
          You can buy directly from sabs.
          If it is not broken, fix/test it until it is.
            Post as many as you can in a wiki, never know when you may need one.
            • murdock
              • Oct 2007
              • 2346
              these would be very interesting threads.
              if we could get hold of some past exam papers and post a question on the site per day then people could answer or assisst with understanding the code better...now that would be a good idea...it would be like a refresher course for some of us ....help with people doing the course and and at the same time make the public more aware of the codes and what is expected of electricians...
              i purchased the code on cd but never updated.
              • murdock
                • Oct 2007
                • 2346
                and to make it more interesting add in some practical experiences from the inspectors....for example
                while carrying out a inspection report...you come across a DB while is higher than 2.2 m above the ffl what action do you take and what would the recommendation be to solve this issue. (common problem encountered)
                do you leave it as is and sign over the coc or do you lower the main switch to below 2.2 m.
                another common one is the db in the cupboard...what do you do.
                so now you buy a property and walk in the kitchen and find the db in the cupboard...if you are not an electrical inspector by reading these post you will know what to expect and if the inspector has been on the property.
                the tv guy comes to fit you arial...what to expect...who puts the earth wire...and where do you connect it...all these type of question related directly to the public...it would make the public more aware and hopefully more people will take the time to contribute...or query installtions by posting pic of their queries.
                • Jacques#1
                  • Oct 2009
                  • 201
                  Ive got one too....... The new ammendment requires surge arrestors be installed in the house. They make reference to this on multiple pages, including a dedicated annexure (L).
                  What do you do if there is no more space in the DB??????????????
                  IJS Installations
                  • 123
                    • 57
                    6.7.6 Surge protection
                    6.7.6.1 Surge protective devices (SPDs) may be installed to protect an
                    installation against transient overvoltages and surge currents such as those
                    due to switching operations or those induced by atmospheric discharges
                    (lightning). Amdt 1; amdt 6
                    Hi Jacques, do they mean "may be installed"? which does not not mean "must be installed"?
                    Regards-Christo
                    • murdock
                      • Oct 2007
                      • 2346
                      this is what i was hoping for...constuctive critism.
                      dave its time to scrap the generator thread and turn it into the sans code thread
                        • 22819
                        I'll be honest - it's exactly this type of interpretive discussion I've been hoping to see a lot more of on this forum.
                        • Jacques#1
                          • Oct 2009
                          • 201
                          If you read Annexure L 1.2.1 Pg325 "Surge protection devices shall be installed at least in the main distribution board of an electrical installation"
                          I also read the "may" part, but then remembered two things:
                          1. An inspector once told me that the book may not always make sense, or there may be double standards, you have to interpret it in the safest reasoning possible.....so if you get a part that is "safer" than a contradicting statement somewhere in the book you must go with the "safer" option. This according to him will convince a judge in court that you were reasonable with the best and safest intentions.
                          2. On the ECA roadshow they discussed the changes. They talked about SPD's and the guy said for JHB its a no brainer, we have guy fox up here every second night with all the lightning, and supply is a problem every once in a while. He then also talked about CPT, said that the CPT guys said they never get lightning, showed a picture of this massive lightning bolt hitting close to table mountain (everybody laughed).....but more problematic is the CPT supply problems as I understand it.
                          Point is, theres a part in the code that says I must install it, and every new house/COC I do I install it. If you are doing a big complex the engineer specifies SPD's at every split in the electrical system. The main SUB, Mini SUb, Block subs and the flat subs.
                          IJS Installations
                          • Jacques#1
                            • Oct 2009
                            • 201
                            I'll answer these....I know you just made a statement and know these answers but...questions since someone may be reading them right now and wanting to know the answer?
                            1. As far as I know you can do an industrial jobbie on the main switch.......take a 1.5mm stainless steel rope, ferrule it around the switch, make the bottom end lower than 2.2m, loop it and ferrule it. Add a sign on the rope (switch off this main switch in the event.......), and one on the DB.
                            2. Db in the cupboard, put a lable on the cupboard door stating the DB is inside the cupboard, and must remain un-obstructed. Take a photo of the lable and you are set. (We all know the home owner pulls that ugly lable off before you turned on you ignition).
                            3. The TV guy should put an earth wire, some does others don't. They should also adhere to any standards related to their industry, regardless of its origin.
                            IJS Installations
                            • 123
                              • 57
                              Annex L.1
                              (normative where surge protection
                              is required or installed (see 6.7.6))
                              It may be installed, and if it is installed, it shall be at least in the main db....
                              Thanks Jacques, I see your point.
                              I was more thinking as a requirement in order to validate a coc.
                              Is it a requirement then? Should the issuer of the coc install it if it is not present?
