fault level
  • murdock
    • Oct 2007
    • 2346
    fault level
    anyone know the calculation to work out what the fault level (short circuit current) is 5 metres away from a 40 kva 400 volt 3 phase generator if i am using a 16 mm x 4 core ecc cable.
    known...
    40 kva
    400 volts
    58 amps
    generator impedance unknown
    i dont want the answer i want the formula and what the impedance of the 40 kva generator.
    Are you going to work it out from test readings or from manufacturers published figures?
