Public or school Swimming pools.
  • IMGREG
    • Jul 2010
    • 21
    I have had a request for a three phase plug in a filter room but to be used outside for pumping water out of a pool.
    I want to install the plug in the filter room. And run a trailing cable lead system.
    Can i Install a 30 amp breaker supplied via a 3 phase earth leakage.
    What would be the safest and most legal thing to do.
    • 4927
    You'll need to figure out the zones. 10142-1 Figure 7.2.1, Figure 7.2.2 and Figure 7.2.3 are relavent. Section 7.2 gives info about earthing arrangements, protective devices, required IP reating of equipment etc.
      This is a very common practise at pools, but most pools I have worked at use single phase pumps.
