Sigenergy
  • Tradie
    • Feb 2025
    • 401
    Sigenergy
    The new buzz word around the solar industry, how good is this equipment and what sets it apart from Victron, DEYE, Sunsynk ?
    The fire suppression on the batteries - Can they be installed in locations that other batteries (without built fire suppression) can't be installed ?
    The easy stack system, which looks great, but you still need a box (gateway) on the wall with all the cables below the unit ?
    It has an inverter of sorts installed in each battery compartment, so the system will continue to operate, even if one unit fails ?
    The software for the end user is better than all the others?
    The tech support for installers and the end user is much better?
    One of the biggest solar supplier in SA support the brand?
    Can you adjust the battery charge rate as required by the municipalities ?
