24 VDC lithium batteries for mecer inverter
  • Tradie
    • Feb 2025
    • 330
    Anyone have any experience with lithium batteries connected to 24 VDC RCT or Mecer voltronic inverters.
    We have the option of:
    2 x 12 VDC 100 amp/hr, which would give you 200 amp/hr instead of 100 amp/hr like the 24 VDC packs.
    1 x Dyness 24 VDC lithium pack 100 amp/hr.
    1 x Must 24 VDC lithium pack 100 amp/hr
    Which are compatible with voltronic inverters and solar assistant.
    Currently I have 2 x 12 VDC gel batteries connected using solar assistant for remote view and adjusting settings, replacement cost around R5000, do I just replace every 3 years (average life span) or can we justify R10 000 for a 24 VDC 100 amp/hr that is half the capacity but can be discharged to 80% DOD compared to the gels at around 50 % DOD.
    Some would say the charge rate is much better for lithium, that would only be considered if the mecer inverter could charge at a higher rate.
    • 1473
    We have replaced the lead acid type battery on RCT type inverters with Lithium 12v drop in replacements - Have left the loads light as there were with the lead acid set and the systems have performed well
    • Tradie
      • Feb 2025
      • 330
      The cheapest solutions seems to be the Esener multi function battery. R8200.00
      Suitable for Axpert inverters
      24 VDC.
      256 kwh.
      100 Ah.
      C1 rated.
      BMS.
      • Tradie
        • Feb 2025
        • 330
        Dyness DL 2.5, best price R8450.00
        24 VDC
        2.56 kwh
        100 Ah
        C1.3
        Not sure if it supports Axpert inverters.
        Thes eliste don data sheet ... Steca/Sorotec/MUST/Victron/Growatt/SRNE
        • Tradie
          • Feb 2025
          • 330
          I am have a choice, Navasolar, Esener or ECCO, they are all priced about the same and within the budget.
