load shedding free lights
The problem with switching DC on and off with an isolator swtch, or any switch for that matter, is the arcing.
When you switch AC the waveform is crossing the zero line 100 times each second, at that zero crossing point no current is flowing in the circuit (excluding PF and harmonics etc) so any arc that occurs at the switch contacts extinguishes itself.
With DC there's no time that the waveform crosses the zero line, the current is constant so switching arcs don't self extinguish which means switch contacts suffer enormous wear and tear with DC.
You do get switches that are rated for AC and DC usage but you'll always find they're derated for DC use. For example a 60Amp AC isolator might be rated for 20 or 30Amps DC use as well._______________________________________________
Car starter solenoids contacts switch very high loads between 300 and 600 amps the contacts are around 8mm, starter solenoid can switch many times per day and they last for many years. I don’t know how dangerous a 120/110V DC system will be I just know it’s very popular, all underground battery locos today are running on 110V DC system. One could reduce the voltage to a safe operating voltage. The question is how many high power appliances do you really have in a house if you exclude the geyser and stove?Comment
Washing machine, dryer, kettle, microwave, vacuum cleaner, wife's hair dryer and curler, steam iron, slow cooker, steamer, espresso coffee machine, swimming pool pump, lawn mower, weed eater, 230V electric gate, .......but a few I can think off hand.Victor - Knowledge is a blessing or a curse, your current circumstances make you decide!
Dishwasher, tumble drier...Participation is voluntary.
Things like lawn mowers that use induction motors won’t work on DC. We don’t have all these households appliances made for DC at this stage. I have been on a yacht some time back and it had many appliances that was DC powered I think they do make many DC products for things like boats but they are expensive because it’s a small market. I don’t think an inverter system is the way to go because of the high consumption on the batteries. A pure DC higher safe voltage system will be a far cheaper option for the future. For now we do have lights that work perfectly from low voltage DC I spoke to someone yesterday that’s converting fridge/ freezers to work of DC. It might take time but DC is coming.Comment
