i was watching people at the house and garden show being drawn in by what seemed to be amazing...BIG SAVINGS...there is a flow meter connected to 2 shower heads to prove that you will SAVE MONEY
...you dont need to buy an expensive energy saving shower head...think about it if you try force water through a 1 mm hole only X amount will come out...if you increase the hole size to 5 mm then a whole lot more will come in other words the flow rate will be higher.
you can buy these shower heads from your local hardware you just need to ask for the one that stings the cr*p out of you while trying to shower...ie the one with the small holes.
it looks like we gone from generator crazy to energy saving crazy...just think a little before you rush out and spend money...and switch things like lights off when you are not using them...energy saving is a life style.
...you dont need to buy an expensive energy saving shower head...think about it if you try force water through a 1 mm hole only X amount will come out...if you increase the hole size to 5 mm then a whole lot more will come in other words the flow rate will be higher.you can buy these shower heads from your local hardware you just need to ask for the one that stings the cr*p out of you while trying to shower...ie the one with the small holes.
