Easyfile merge problems
  • miello9
    • Oct 2012
    Hi good day,
    Can somebody tell me if you do a backup of E@syfile, if it is suppose to back the file as a zip file?
    Because mine does, I am not able to use the merge function, as the merge function doesn't seem
    to read the zip file.
    Please advise.
    thanks,
    Miello
  • Mike C
    • 2894
    Hi miello9 - yes it now zips the data. Started doing this from about version 6 I think.
    I have never done a merge, but it should be possible from within Easyfile.
    Merge multiple databases
    This process should be used where:
    • Multiple branches or different employees complete manual certificates and payroll files, and these should be merged for the
    reconciliation.
    • Data for different financial periods should be merged onto one single database.
    With the introduction of split database files for each PAYE number within the e@syFile™ Employer directory, the merge process has been amended to combine one employer database file at a time. When merging another user’s data with your existing e@syFile™ Employer database, one employer database will be selected, to merge with your data.
    This will enable tax practitioners, payroll consultants and users with multiple PAYE reference numbers to create e@syFile™ Employer database or back-up files for a single PAYE reference number.
    Note 1: To ensure that no certificates are lost during the merge process, different certificate numbers or ranges should be
    assigned to the different staff members preparing manual certificates. Back-up all data to be merged, and transfer these
    files to a selected folder on the PC where the various databases will be merged.
    Note 2: A new backup file (version 6 and later) will need to be ‘unzipped’ before the data can be merged with the existing
    e@syFile™ Employer data. Access the folder where the back-up has been saved that you wish to restore. Extract or ‘unzip’
    the file before proceeding with the merge process.
      Looks like that's the key.
      • tax$$$
        • Jun 2011
        • 39
        Hi miello
        Its like they say, unzip and merge them one for one. Be careful though. I merged a file and EasyFile 'not responded' and had to force exit. For some reason all files under AppData was deleted. Just make sure you backup every time.
        • Mike C
          • 2894
          Very good advice Tax$$$
