Travel allowances - is there a limit?
  • Connie K
    • May 2013
    • 14
    My client travels approximately 4000 km a month (both business and private). An estimated 20% of his travel is for business. Based on this mileage and his vehicle, which is at the R480,000 threshold, we would like to structure a travel allowance of R20,000 which approximately R4000 is tax-free and R16,000 is taxable. The question is - is there a limit on the travel allowance? Especially since the bulk of it (R16,000) is taxable in any case?
  • Andromeda
    • Feb 2016
    • 734
    Hi Connie
    You will be better able to arrive at your own answer if you dispel some misunderstanding.
    Actually there is no tax-free portion. It is recommended that 80% of the allowance is subjected to PAYE, while the 20% is subjected to income tax on assessment. On assessment, a deduction is allowed against the whole allowance and I assume that you are ok with how that works.
    So in a nutshell, there is no limit as such, because the entire allowance is actually taxed, after allowing a deduction. By making the allowance very high, you would be doing the client no favours because his allowable deduction would then most likely be less than 20% of the allowance, meaning he would be a tax shortfall position.
    • Connie K
      • May 2013
      • 14
      Hi there
      Makes total sense - thanks for that!
      Kind regards
      • Christel
        • Feb 2012
        • 362
        If you are certain that he will travel more than 8000km in the tax year for business purposes, then you could tax only 20% of the travel, instead of the recommended 80%.
        • capetowncheapflights
          • Mar 2017
          • 6
          you must check all taxes and fees also
          cape town cheap flights
